bfmonaghan
Hello all
New to board and first post, but hopefully I can get some advice with a couple of problems I have with a 1907 farmhouse that I bought 6 months ago.
Problem 1:
The main house has a gable-end single floor extension which houses a large utility room and a play room. The floor of the utility room is concrete with no dpc and is level with the outside ground level. When we bought the house, the utility had lino. When we removed it there was a lot of damp beneath which dried up pretty quickly. I want to put slate flagstones down to improve the floor appearance, but am trying to work out the impact of no dpc. My original idea was to put in a dpc and a thin concrete layer, raising the floor level by about 1.5 inches. But the more I think about that, the more convinced I am that it will just result in the damp being pushed to the walls - since the floor is level with the ground outside and no opprtunity to install air bricks. So, I'm thinking that a better idea is to check out the breathability of the flagstones and go with a permeable means of fixing them to the concrete - but not sure what that fixing might be.
Problem 2:
The play room has developed a very damp lath and plaster wall where pointing at the corner of the room (where it joins the main house) has been washed away by overflow from a blocked gutter downpipe. The downpipe has been cleared. The pointing has been a nightmare to put right, since it's in very narrow horizontal gaps between square cut corner stones. So, I've had to push the pointing in with wires to fill the gaps. Given the narrow gaps being filled, the amount of mortar used has been very small, but it's taken a while. On the advice of a neighbour (a landscaper) I used cement pointing. So, the water ingress seems to have stopped affecting most areas of the wall and the plaster is drying out. The effervescence has stopped and I'm about to treat with salt neutraliser. However, there is one area, at waist height) that refuses to stay dried out. Running our dehumidifier results in a temporary drying, but it soon gets damp when there's any amount of rain. I've looked over the outside wall in detail and can't see any obvious remaining mortar problems. So. I'm thinking that water may be getting in through the stone, or that the cement mortar may have stopped water ingress, but be preventing natural evaporation. But the gaps pointed with cement are so thin that I'm not sure much water could have evaporated out of them (as opposed to the volumes running down the stone, then along the top of the unmortared gaps). Am not keen to take out the l&p to find the source, but can't do much with a wet wall that won't dry out.
Any thoughts or ideas appreciated.
Brian
Problem 1:
Problem 2:
Brian
