zaceverett
I've lowered the outside ground level and i dont have any footings i've highlighted in red the row of stepped bricks which has nothing but clay underneath.
Any suggestions as to what to lay on top of the clay soil for the path?
Can I leave the bottom row of stepped bricks exposed like they are?
I was thinking of putting some kind of plastic dpm running along the bottom row of brick and then putting some stones down for the path.
Initially i was hoping to lay a drain. I will try this a bit further away from the footings? And suggestions on distance?
Also my internal concrete floor that i'm removing is only 3 inches thick and level with second course of bricks(just above red line) on photo.
Can I dig down internally against the footings to lay some kind of limecrete floor?
Any help appreciated. Builders dont seem interested in this job.
