charlieworld
- Welshpool / Shrewsbury
Hello all,
I have a C16th timber framed, Grade II* listed house on the Eng/Wales border.
In the centre of the house is a typical large chimney servicing two fireplaces, one on each side, and a bread oven on the third side. (The fourth side is yet to be uncovered!)
After removing some flaking cement plaster, I have discovered a further shaft into the chimney on the same face as the bread oven (although floor level and 2-3ft away).
This access is approximately 45cm wide x 60 cm high and is supported by a narrow metal lintel to the top.
Does anyone know what this might be???
Many thanks
charlieworld
Many thanks
charlieworld
