Work continue on my inglenook fireplace - I've removed quantities of modern concrete chunks and layers of gloss paint. I have a big tub of klingstrip en route to deal with the back wall!
The main area I'm working on at the moment is the right hand alcove and the little window that was probably originally either an oven or a salt cupboard.
Thrown up a few surprises - The inset sill below the window (big enough to sit on) turns out to be a whacking great piece of oak. There are burn holes in it (of the bored child variety I think) and a large chunk of metal (not rusty). I've stripped around 8 layers of gloss off and I'm planning to beeswax it up and leave it as bare wood rather than repaint.
The alcove has also been interesting.
To describe it, there is a large oak seat, brick walls with lime plaster on the bottom half and daub and plaster at the top.
Outside of the alcove is a small brick arch (above is normal brickwork and daub); arch is one brick deep and then goes into a half-domed section made (as far as I can see) of daub and plaster with bits of roof tile shoved in. That butts up against a flat "ceiling" which is another slab of oak. (The other alcove is completely different, just a very simple box)
All of this has been covered in chunks of cement, expanding foam filler and gypsum and then the gloss paint layers.
I've just about finished getting the modern stuff off. I'll then photograph it all.
I'm planning to repair the daub and then lime plaster the whole inside of the alcoves. However...
Would you plaster over the oak "ceiling" or leave it as wood? Should I leave the arch exposed and plaster around it?
A lot of the old lime mortar and plaster is friable and in a terrible state. I imagine I need to have a stable surface to work with for the new plaster to go on, So should I photograph it all and then strip out the loose stuff?
Livia advised me to watch the arch as they weren't always well built. It seems pretty solid but I'm a tad anxious now as a lot of the work that needs doing is inside the archway and given the inglenook is nearly 10 ft it's not a small chimney above my head!
Hence I'm wondering if I should buy a couple of little acrow props for this and potential future anxiety?
Also celebrating that my CO has signed off all my current works via email as not needing LBC and is very happy with what I'm doing.
Regarding my inglenook hearth he's even suggested I get in all new bricks, lay them in NHL but butt them up without mortar.
Big relief as most of the bricks are in a dreadful state and most are modern anyway.
