I've a 300 year old cotswold stone cottage I bought 4 years ago. An internal wall has damp because someone about 15 years ago chopped all the plaster off, had it injected and then plastered it with cement and gypsum. So I'm taking the cement & gypsum off so I can redo it in lime plaster and then limewash.
I'm trying to do as little damage to the stone as possible, doing it with mallet and chisel. The gypsum comes off ok - some of it needed no help! - but chopping the cement off is very tedious and time consuming indeed and I don't want to use a power tool. So I want to only chop off what I need to.
Will I get away with this: Chop back to the stone on the lower part of the wall, but not worry about small patches of cement left (to try and minimise stone damage). On the top part, just take off the gypsum and top layer of cement but leave the bottom layer. Will the Lime plaster take over the cement?
