thiambal
- Walmer, Kent
I have a late victorian terraced house with a kitchen at the rear of the house in original extension (the bit of the house sticking out the back that is not as wide at the main house) at the rear of the property.
When we moved in there was a fresh self leveling screed laid on the kitchen floor and new kitchen installed. We have have lino laid for about six months and now scattered damp patches have appeared on the screed. They are not wet but feel clammy and dry out when left exposed for 24 hours.
I believe there is concrete below the screed but I have no idea how thick and presummably without a DPM. The kitchen floor is six inches lower than the boards in the main house - so I guess is is possible that there was orginally an earth floor that has just has a bit concrete poured on top - or the room has boards which have been filled in.
An option of course is to dig up the whole floor and re-lay with DPM but this mean removing the fitted kitchen at great expense. As the screed had been down for some months when we moved in with no sign of damp I imagine the lino is just stopping the floor from breathing. There is no sign at the moment of rising damp in the walls - although they have been recently skim plastered and painted.
So the questions are these:
1. Do you think we will get away with not digging the whole lot up?
2. What sort of breathable surface could we put down - would quarry tiles be suitable. - Or could you recommend another - perhaps thinner alternative as the floor is currently only a few mm below door step of exterior door.
3. If we were to lay quarry tiles would we be best to use tile adhesive or some other method if laying onto the existing self leveling screed.
