Hi
I'm planning a refurb of our Victorian coach house (solid walls). A couple of the rooms downstairs are very cold in winter since the external walls in those rooms get particularly cold. Hence I'm considering internal insulation - breathable, wood fibre, lime plaster etc. This is more about room comfort as first priority, than saving energy.
My understanding is that ideally (usually?) you would apply IWI to a whole elevation, ground and first floor above. But in my case that would triple the complexity given the configuration/detailing upstairs, and the rooms above are pretty comfortable as they are. I think the risk of doing ground floor only, supposedly, is that moisture is then more focussed on the relatively colder walls in the upstairs room, increasing the condensation risk in that room. (That's my crude understanding but TBH i've not found it articulated very clearly.)
I would hope, however, that going with a modest 40mm of breathable wood fibre downstairs (and up between intermediate floor joists) would mean the risk of this unintended consequence is pretty low.
I'd be interested in any perspectives on this and whether in reality it's very common to insulate on a room-by-room or floor-by-floor basis vs whole elevation all at once.
Many thanks!
Many thanks!
