Hi all
It has been a while since I've been here.
Can I please have some advice.
There is a single black spot (about 7mm) on the inside wall between us an our neighbour. Not major, you may think, but:
- We're end of terrace and the outside wall has considerable work on it, about seven years, for damp; the inside wall in the corner had a little bit of damp identified though we left this
- The bedroom upstairs and the room below, that the corner of the wall where the black spot is, shows slight movement - the plaster /wall has cracked about 1mm
- I've repainted over the black spot again and again and it is appearing through
So - could this be the sign of a major problem? Damp? Subsistence?
I appreciate this is minor - buy we're concerned that there is a bigger problem to happen.
Thanks in advance.
Ray
Thanks in advance.
Ray
