Hi All,
About a year ago we moved into a blue lias & timber 19th Century house. I've been slowly investigating some of the issues with the house and would appreciate some advice on the damp we have. First a few observations:
* Almost all the internal walls (not the inside of the external walls) are damp (blown plaster, falling-off tiles, 100% disintegrated metal switch boxes)
* The previous owners have had chemical DPCs (which are under guarantee) inserted all over the place on at least 2 different occasions
* The whole ground floor has new stone tiled floor
* There are no obvious sources of external damp
* The walls have lines around them at about 1.5m up which I assume are where new waterproof plasterboard's been installed
* The worst wall (piccies below) is against the staircase and the under-stairs cupboard is pretty damp smelling with some signs of active woodworm in the stairs
* The DPC company have said they'll re-inject the DPC for free (and charge me for the pleasure of replacing the plaster)
From browsing round this forum & website it seems to me this isn't condensation damp (not on cold walls, no mould) which only leaves rising damp. My question (of course!) is how to deal with it? Is the right course of action to rip off the existing plaster and replace with lime-based plaster? Will I need to leave the wall to dry before replastering? Has the new floor meant the walls are going to be damp whatever I do (in which case should I give up and go with the "modern" solution)?
Grateful for any advice!
Thanks a lot,
AdamView attachment 2View attachment 1
Thanks a lot,
