supermattt
- London E1
Hello All,
I posted this on the old board without relising it was the old board. This board seems busier so I have reposted here:
I've bought a ground floor flat in a row of 'Silkweavers Cottages'. There is a damp issue which I knew of when I bought it, and which I am now trying, by a process of elimination, to solve.
The main symptom is in the kitchen where there is blistering of the paint and plaster on an interior wall. I have pulled away the plaster where it is loose, and it appears the finishing plaster is set on top of mortar (hard, grey looks a bit like concrete), and then I assume under that, Brick. Non of the mortar is crumbling. The blistering starts above the skirting board which is sound, no rot or softness.
The back wall of the house, inside of which is the bathroom, also displays similar symptoms, though it seems quite obvious that this is from a leaking window sill. The first time it rained when I was in the flat I noticed the guttering under the roof at the back was broken and water was more or less pouring onto the window area. The sill is parlty rotten.
So, I have had the guttering fixed and am planning to dig out the portion of the wooden sill that is rotten and fill it with some waterproof exterior filler substance (any suggestions?). I am hoping this will deal with the back wall.
Where I need help then, apart from any practical advice anyone has, is in dignosing the more elusive cause of the Kitchen wall. There are damp patches in other parts of the house also, all near the floor, 2 of them near/ around electrical sockets (the channels for which I thought may be conduits).
The Floor throughout as far as I can tell is concrete and is covered in laminate wood flooring. There is a vent through a front living room wall to outside which amounts to a hole in the wall and there is an uncovered fire place which I suppose also amounts to a hole in the ceiling....things I guess might be contributing.
I have taken some of the plaster off in the kitchen and the wall is not damp underneath though there is some salty deposit.
Can anyone recommend a good step by step elimination-of-causes-one-by-one type book that I might be able to purchase?
My current proposed strategy is to replaster the wall in the kitchen with something breathable (lime plaster?) and see if stays.
Any thoughts, hints, advice or comments very gratefully received.
With many thanks
Matt
With many thanks
Matt
