damp+dusty
- somerset
We are starting to look after a 1790s stone cottage that we have very gratefully inherited. We have been reading previous posts with great interest and would value the forum's experience with our building please.
The inside of the cottage feels damp. If we are on holiday for a couple of weeks we return to a really damp feeling and smelling building. There is condensation streaming from the glass in the mornings and there are a couple of salt patches on the walls at ground floor.
We think we need to reduce the moisture inside in the building. It currently has a log burner and some electric infrared heaters downstairs. Upstairs there are radiators that run off the log burner ie only work if the log burner is lit.
We have discovered that in the late 1970s the property was given a silicon injection DPC and then the ground floor walls were rendered internally with a finish that included a Peter Cox salt retardant additive.
The first floor walls are plastered in a more standard way although we do not know if it is lime. We have only ever painted with breathable paint since it was re-plastered, also in the late 1970's.
We are wondering whether the internal rendering might be preventing moisture from escaping the cottage as easily as it otherwise could. We would value thoughts on this, especially as the work was done in 1979 - will it still be working / preventing moisture getting out or does it eventually stop becoming a barrier?
The internal render is not particularly attractive so we were thinking of plastering over with lime plaster but now we are thinking that lime plaster over render is wrong because the render is less breathable. Is that correct?
The ground floor is a concrete slab. Do we need to replace that with limecrete to make it more breathable?
We are considering fitting a positive input ventilator in the roof, perhaps with heating option to try and increase the overall temperature within the property which faces north onto a road with another house only 6m away so limited sunshine/solar gain. We are not sure whether this will be successful though because of the internal render potentially preventing the moisture escaping?
We are also considering fitting additional fans to the bathroom and kitchen with moisture sensors so they come on automatically (hopefully to help with human/teenage error).
We are going to replace the 50 year old log burner with a new more efficient one and also fit electric rads upstairs (to hopefully run off PVs). BTW there is no gas in the village and we do not want to install oil at this point.
We'd be really grateful for any thoughts regarding the above. Keen to make the right decisions for this old cottage! Thank you
