harkerhill
Hi
I've decided to start decorating another room in my <strike>1950's</strike> (sorry I meant 1750's!!) brick built farm house.
Once again, it's a matter of taking out the 70's novelties and making the room more original.
So far I've taken off the 5 layers of wall paper, removed two pine units (either side of the fireplace), taken the over sized fire surround out and binned the bright red curtains
Now that I can see the plaster, I can see that it's been patched many times before with lot's of old and new layers on top - skim after skim. The exterior walls are damp (the outside is concrete render which is cracked in places).
My question is how to proceed next?.... For the internal walls can I just scrape off the loose and reskim?
For the external walls, I presume lime is going to be much better to allow the wall to breathe. Does that mean removing all of the plaster back to the brick work?
Many thanks in advance.
