With a condensing boiler, efficiency rises when the flow (more precisely, the return) temperature is below ~54°C. The lower the temperature, the better the efficiency (see graph below).Can you explain about the low flow temperature bit I am not aware of this and we have very few radiators.
cast iron heaters will heat the wall behind it and a lot of heat is lost there
Thought it was fairly standard practice to put radiators under a window to counter the sinking cold air coming off the glass. But with decent double/triple glazed windows, an internal wall is my preferred option.One of my earliest upgrades was to replace the single steel panel radiator in the living room with two last cast iron rads. One under the window, something else heating "engineers" will tell you not to do, another "rule" being always always put radiators on an internal wall to minimise heat loss.
I'm thinking about getting cast iron heaters in the near future because I read that they retain heat for longer periods after the boiler shuts off due to their high thermal mass. And they're great for maintaining warmth in continuously used spaces. My plumber suggested panel convector heaters are better though - apparently they heat the room more and circulate it through the room better, which cast iron heaters will heat the wall behind it and a lot of heat is lost there in that spot. I'm not sure about that though.
100%.It's true that the (usually) higher thermal mass of cast iron radiators retain heat for longer than standard radiators after the boiler shuts off, but the consequence is that they also take longer to warm up after the boiler is switched on. Sadly, it's not that easy to avoid the laws of physics. The boiler can only generate a certain amount of heat and the aim is to 'lose' that heat into the desired room(s). There are various ways of 'losing' that heat into a room, e.g. light steel radiators, heavy cast iron radiators, underfloor pipes that heat the floor, etc and each method will 'lose' that heat into the room at different rates over different times, but there is no method that I know of that can 'lose' more heat into the room than the boiler can provide. All that each method can do is to take more or less time to heat up and cool down.
I thought siting rads on an internal wall was a no, no?Thought it was fairly standard practice to put radiators under a window to counter the sinking cold air coming off the glass. But with decent double/triple glazed windows, an internal wall is my preferred option.
I thought this too. I thought rads had to be under a window too because.. science? but maybe it's not really needed if you have double glazingI thought siting rads on an internal wall was a no, no?
The largest cold surfaces in most rooms are the windows, siting radiators under these stimulates and accelerates the air convection currents in the room to heat that room more effectively. Placement of radiators elsewhere other than near a window merely reduces the speed at which the room can reach an ambient temperature while drawing colder air from more distant sources.I thought this too. I thought rads had to be under a window too because.. science? but maybe it's not really needed if you have double glazing![]()
