Tom
- Charente, France
Hi everyone!!
Gosh it's seems years since I posted here! Doesn't time fly when you're having fun? :lol:
Anyway, Our front door has been made and is wedged in place until we can get the hinges made. But it's raised a problem. I was planning to leave it unfinished, so it could go all nice and silvery as the wood did when it was stood in the yard. However, the joiner says it needs waxing or oiling to prevent it warping. It's made with 2 layers of 1" thick boards. Outside these run vertically and inside they run horizontally. The boards on both sides are 12" wide. Overall, it's about 4' 6" wide by about 7' high. The boards are glued together and will soon have huge rosehead nails driven through from outside to inside and bent over on the inside. These will be more decorative rather than structural, although I guess they will add some strength.
My joiner thinks that, because of the temperature and humidity difference between the inside and the outside, that the wood will warp. What does everyone else think? Incidentally, the wood is either Oak or Greenheart(?). It had been intended as lock gates, but was never used. Instead, it stood in the open air for 20 years, stacked flat on bearers. I've had it for 6 years and, again, it's been in the open. For the last 4 months, it's been in the joiner's workshop.
Please help as the last thing I want is for this door to be ruined.....I've waited years for it!!!!
Jaqy
Jaqy
