A
Anonymous
Guest
I took the up the cause and have started to replaster my exposed brick fire place in lime plaster, but as it has been drying over the last few days a nasty brown stain has soaked through from the brick work. I suspect it is tar from inside the flue going through the original lime mortar when i have dampened the bricks prior the plastering - is this true? and how should i hide this? I have only put the first coat on of about 1/2 inch. Is PVA a good idea or not?
