piapiapiano
I've been lurking here for a few weeks, and I've finally decided to take the plunge and ask for some help/advice from people who know what they're talking about (ie. you lot!). (Sorry this is so long. I wanted to get it all straight in my head so there is perhaps more detail than is really necessary.)
I'm in the process of buying this house and I'm getting very confused by all the conflicting things I've been told.
It's a 150-200 year old traditional stone-built terraced cottage -- probably limestone or sandstone, but it's hard to tell because the exterior is covered in a lumpy cement render -- and it's terribly terribly damp.
The chimney stacks on both sides (one of which belongs to a neighbour) are in bad repair. There are visible damp patches running down one gable wall. The attic was recently converted and they dry-lined the gable walls so you can't see any signs of damp up there, but I expect the stone walls are wet behind the board.
The guttering is full of plants and moss, and at the back of the house the downpipes simply stop halfway down, so that rainwater just runs down the wall.
There are small cracks in the cement render at the front and back.
There's a modern extension at the back, with a balconied terrace affair on its flat roof. The internal wall underneath where this flat roof connects to the old house is also damp.
The internal ground floor is no higher than ground level -- a cement yard at the back of the house, and a road right alongside the front of the house with no kerb (where presumably the DoT have kept on adding new layers of tarmac over the years so that it's now level with the floor).
The exposed stone fireplace/chimney breast has been re-pointed with cement, and coated with some kind of clear varnish, and the hearth itself has been boarded up with an electric fire plonked in front.
The ground floor is just concrete: concrete, with a layer of plastic on top, and underlay and carpet on top of that. Underneath the plastic the concrete is wet.
The mortgage valuation came back with a recommendation that we get it checked out by a damp/timber specialist. Unfortunately, where I live the only damp/timber specialists are people who have a vested interest in suggesting chemical DPCs. The damp/timber survey duly came back with a recommendation that we spend £3000 on an injected DPC throughout the ground floor, stripping off the plaster to 1.2 metres, and re-plastering with some kind of anti-damp anti-salt stuff, and, separately from that, also get the chimneys and gutters repaired. They didn't look at the floor.
The front of the house was bulging slightly so we had to get a structural engineer to come and look at it. He says we'll need to strap it to stop it from moving any further. I asked him to doublecheck the damp situation while he was there, because I didn't trust the damp survey. He agreed with their analysis, but also checked the floor -- and has suggested that we'll have to rip out the concrete and put down a proper DPM, lapped up the walls, before re-laying more concrete and proper insulation. He also agreed that we should have an injected DPC, because it turns out that he does trust the damp specialist.
So now I don't know what to do. I've talked to two different chartered surveyors, who both agree that we'll have to get a chemical DPC. (Again, as with the damp specialists, I don't know of any surveyors in my area who specialise in old buildings.) Everyone agrees that the damp specialist is great. I will apparently find it very hard to sell the house in future if I don't get a chemical DPC.
Based on what I've read on-line, what I think I need to do is:
1. get the chimneys, downpipes and guttering repaired.
2. strip out all the internal plaster and let the walls dry out.
3. get that varnish stuff off the chimney breast, re-point with lime, and reinstall a proper fire.
4. eventually, when funds permit, remove the cement render and replace with lime.
But I don't know what to do about the floor. Although it'll be fine to lower the ground level in the yard, I don't think there's any way I can lower the road level at the front of the house. The house is only a few metres above sea level so I'm assuming the water table is probably pretty high. Anyone got any ideas?
The structural engineer thinks it'll cost us £10,000 to sort out the damp problem. If the mortgage lender imposes a £10,000 retention then this will all be moot, anyway, because we won't be able to afford to buy it. If there's anything I can do to bring this figure down...
