The plaster in our house has rounded or bullnose corners and we want to reproduce these in a new extension. My understanding of how these were formed is as follows:
A staff bead, a 1 inch dowel with approx 1/3rd shaved off the back, would be set on the external corner by the joiner on site fastened to wooden plugs which were set into the brick/block seams or to the wood frame. Plaster was run up to the corner then "quirked". In architecture a quirk is a small 'V' shaped channel used to insulate and give relief to a convex rounded moulding, and here it is used to hide the eventual small crack that will form between the staff bead and the plaster. I have attached a sketch to illustrate what I mean.
My question is, how best to form the quirk? I have read that you plaster backing coat (browning) right up to the outside face of the staff bead, and then cut out the quirk in the backing coat a little larger than the finished size. When you skim, again you skim the staff bead fully in and then using a straight edge, re-cut the quirk to the finished size, usually on an approx 45 degree angle into the bead. But this sounds a bit tricky to get consistent over a number of corners, and if all the quirks are slightly different it could look a mess. Does anyone know if there are special tools or techniques for forming the quirk other than just using a straight edge and experience? I am thinking of grinding a tool that would ride on the staff bead to form the two quirks at the same time but I have no idea how practical this would be. Any comments or suggestions gratefully received!
Regards - Brogden Fields
